http://martinsliquidlab.org/2009/03/26/r1-fan-testing-pq/
this is a PQ curve for common fans.
if you don't mind noise, the Scythe SlipStream 1900 rpm remains a great choice, but this fan needs to stay push/pull on radiator, cause cross radiator, the airflow drops a fair bit. but keeping it at push/pull pretty much elimates this problem.
( been experimenting myself, problem with this fan, is the relatively 'large gap between the fan blades and the rim, so if there's pressure ahead, the air doesn't go through too well. I also managed to overcome this problem by adding a fan funnel (to make the air harder to slip back. and the fan is Excellent since)
SlipStream still performs better on the PQ curve than most 25mm fans.
