- Sep 10, 2013
Finally finished my build and would love some feedback : https://uk.pcpartpicker.com/list/39xF4q
I'm going to be using this on a 1080p build 144hz monitor. Am going for a white theme with the RGB. One color will do me fine. If i see rainbows I'm going to have a seizure. My build budget was around £2000
My main 3 components which i want to get recommendations about are:
Cooler: I did so much research on this it hurts, i wasn't sure if i should go for the x62 or the h115i pro or even the Noctua - NH-D15, however i decided to stick with the x62. I'm hoping it lives up to what i think it can do. Keep the 8700k cooled while also look good in the case. However i wanted to know if people think i should go for the Noctua - NH-D15, then buy the fans which are black with black.swap heatsink , but I',m not sure if its worth the hassle. Also i was worried about the future and that it may block Ram slots if i wanted to go for 32gb which I'm still thinking about. I live in Sweden right now so its always cold so not sure if thats going to help anything
Case: I had three options here : "Phanteks - ECLIPSE P400S" , "NZXT - S340 ellite" , "Fractal Design - Define R6" I think the 400s looks great and has had a great amount of positive reviews. I also got 3 "Corsair - LL140" fans to add in. Would love some opinions on this.
Storage: I know people have been saying to get the 970 evo 500gb but i saw the "Crucial - MX500 1TB" and its a really good deal and wanted to know if its stupid to do this or not?
Again i would just love some feedback on parts that you might change or if you have had any experience with these. Last time i built a computer was 6 years ago so a lot has changed
Thanks xx
Thanks xx
