VastPenumbra
- Dec 6, 2018
Hi, I am about to embark on my first build and thanks to this excellent forum I have not had to ask a lot of questions. However, there are a couple of things that I am still having trouble finding a clear answer for.
1. I am using rigid tubing, is a tee/drain port set up necessary/recommended? I see some people have said they never use drain ports because they just pop off the cpu block to drain but I worry this might be difficult to do safely with rigid tubing.
2. I am using this reservoir: https://www.ekwb.com/shop/ek-res-x3-250-rgb
The instructions recommend connecting input/output to two of the outlets at the bottom of the reservoir (specifically the ones in the first picture). Shouldn't the input go into the top of the reservoir to utilize gravity?
3. Are the biocide liquids hazardous to humans? If so I would rather do silver coil, any recommendations?
Much appreciated for any help.
