I agree, enough time spent.
Last comment though, the Hadron really isn't overpriced when you consider that a 1U 500W Gold PSU of any decent quality is $90+ easily and a good case is AT LEAST $50
Its a nice case, but I've had and worked with micro and mini itx plenty to know it can be a pain to build even for experienced builders. When I said mixed reviews, yeah the ones that went like this tend to worry me a little (not alot but a little):
"Cons: Wow where should I start they my wife about had a heart attack when this firecracker started going off the power supply started popping so loud it was crazy it shot sparks out catching a newspaper it was sitting on on fire and smoke was just rolling out of the case all this after about 30sec of running it cook every part that was pluged into it"
"Cons: cables are actually extremely short... usb 3.0 does not even reach motherboards port. FRONT GLASS HAS SCRATCHES! That is a major let down! the glass came all scratched up!"
"Cons: - No mobo CPU cutout for installing different heatsinks
- No room for cable management"
"Assembly with the optional slim optical drive can be a slight inconvenience, but again it is very understandable with the compact design. It does also mean you need to spend double the cost on the proprietary optical drive too."
"Cons: Absolutely No Cable Management
No CPU Cutout for Aftermarket Coolers
Poor wire colors (I mean come on, a tan HD audio connector out of the 90's?)
Non Removable Hard Drive Cage
Front Glossy Panel Attracts Fingerprints
Front Panel Held On By Glue
Side Window Scratches Extremely Easy (even with a microfiber cloth)
Missing Powdercoat on Some Internals
Bad Audio Interference from Front Panel Connectors
Power Supply Cables could be better"
On and on. Most of the reviews are still positive but almost everyone still lists cons. I understand egg reviews as well as anyone and know how to take them with the grain of salt they deserve, but I also know how to spot patterns and what to avoid because of them.
