I wouldn't buy another pump until you see how well your current list of hardware will work. AFAIK no one else has tried this with an expanded loop so we honestly don't know how well it will work.
The MCP350 has good pressure but the flow isn't so great. But I think that pump is a little more than the MCP350 - I know Swiftech says it's the same but the "top" IS different from the original and might be slightly better for it. IMO - there's no good reason at this time to buy another pump, what you have might work out fine so why spend the money? The worst that will happen is adding a second pump a couple of weeks from now, and that will be easy enough to do if it's needed ...
IMO you've just wasted some cash, for £35 you could of got a Swiftech MCR320-QP rad. That's a lot more cooling power for £10 less.I have bought these extra bit's to add to my loop, i went for a second 120.1 Thermochill rad instead of replacing the 120.1 res/rad combo with a 120.2 rad res do you think i made the right choice?
Alternatively, for only £6 more you could fo got a Thermochill PA120.2, again a lot more cooling power.
In his case, I think he was looking for the easiest solution as far as moutning a new radiator, and placement in his case.
Dual rads aren't necessarily a bad way to go. He has a pump with a ton of head pressure, and some peopel just don't want ot have ot cut up a case.
It would be kinda' nice to have some fresh air going into the CPU area for that second rad. I think I'd leave the top mod as mesh only for a large area pressure equalizer ...
Blow holes work on the pressure difference between the inside and outside of the case. While I'm sure you'll have some air being pulled in it may not be much depending on how much air is being pushed in the front and the CFM difference between that and the rear case fan plus the PSU. Mounting a fan there blowing in would guarantee fresh air delivery to the rear fan.
Just my two cents ...
