QuietIce
Disabled
- May 7, 2006
- Anywhere but there
The rad won't fit if you turn it on it's side? What's the inside width (depth?) at the front fan ...???
Got my kit fitted today i will post pics soon
Looking good. Benchmark that sucker. I'm really curious to know how that Apogee Drive block works out for you. I think Swiftech might have hit a home run with it, and that it might become the WC newbie block of choice. So far looks like you have great performance.
How much voltage are you pumping through your CPU?
1.45v on the vcore any benches you would like to request?
Yeah, ambient temps are a pain. I hear ya.
Those Idle temps are looking a bit high.
Do you have those old hot water radiators? Liek in old buildings?
I was living in an aprtment in Chicago 4 or 5 years ago that had a MASSIVE radiator right near where my computer was. When that thing cranked on, my temps jumped about 10 degrees. Thing is, I didn't have anywhere else to put my Computer.
Oc1, looking good, thats a nice setup you've got yourself there.
You might want to edit your sig, I'm guessing your CPU is, nor ever was, cooled by a Thermaltake Ultra120 Extreme. As, unless Thermaltake has majorly infringed some copyrights, thats a Thermalright heatsink.
...unless Thermaltake has majorly infringed some copyrights, thats a Thermalright heatsink.
