So this is my first time building a computer, a gaming computer specifically, and I just wanted some input from more experienced people about some of the parts I'm thinking of buying. I'm basically going to use this for high end games, but wanted to keep it fairly budgeted. Right now I'm up to about $1,300 including keyboard, headset, speakers and the such and that's my limit pretty much.
Here's the essentials:
Motherboard: ASRock P67 EXTREME4 (B3) $160
http://www.newegg.com/Product/Product.aspx?item=N82E16813157229
CPU: Intel Core i5-2500K 3.3GHz $225
http://www.newegg.com/Product/Product.aspx?item=N82E16819115072
GPU: EVGA GeForce GTX 570 $340
http://www.newegg.com/Product/Product.aspx?item=N82E16814130593
PSU: CORSAIR Gaming Series GS700 700W $110
http://www.newegg.com/Product/Product.aspx?item=N82E16817139024
RAM: G.SKILL Ripjaws X Series 4GB (2x2GB) 240-Pin DDR3 $55
http://www.newegg.com/Product/Product.aspx?item=N82E16820231443
*Should I go with more RAM or will it really matter in the long run?
HD: Seagate Barracuda 1.5TB 5900RPM $60
http://www.newegg.com/Product/Product.aspx?item=N82E16822148725
CPU Heat Sink: ZALMAN CNPS9900MAX-B 135mm CPU Cooler $70
http://www.newegg.com/Product/Product.aspx?item=N82E16835118074
Any help would be appreciated! Thanks
