- Mar 1, 2005
- CA
Hi all, I came over here since [H] wouldnt answer anything. I was bored, so I decided to do a lot of research and cheaply water cool my old 1600+ begging to be used for something. So far, this is what Im looking at:
Via Aqua 1300
'77 Bonneville/'86 Chevette HC, probably Chevette since I need 120mm fans and I dont want to spend for more than 2
Tuberware/PVC reservoir
Homemade waterblock, either a popcan, beehive, or a spiral, I still need help deciding which would be the easiest to make (I have no access to a mill), least expensive, and how big a piece of copper Ill need
Already have 10' of Home Depot 1/2"id-3/4"od tubing for $6.50 after tax
I also need help on figuring out which barbs Ill need, and anything else you think I need.
Via Aqua 1300
