what I would do with the voltage and LLC is this. Set the Cpu Vcore to 1.476 which was the highest that Hwmonitor read under load and with the LLC on Normal run prime again, with HWmonitor open. Post a screen shot of Hwmonitor again so we can see what the voltage did under load, if it droops significantly again or you get an error we'll take it from there.So the options i had for Vcore Line Calibration was... Auto, Normal, Extreme, Medium, Low, and Standard... I went with Normal? Does that sound right?
Here is the memory screen shots... First 2 are A Channel... Second 2 are B Channel
If that's 3 hour's of Prime blend you're good in my book, I'm assuming you're still at 1866 Mhz on the ram, 11-11-11? I definitely would like to see the Cpu Voltage under control a little more, .06 variance is a bit more then I like.Backed the frequency down to 4.5 and ran for 3 hours with no problems. Also switched the LLC to "Standard". I believe there is still a voltage drop though.
Sorry I'm trying to help too many people, I thought you were using 1866 sticks.I was never able to get the RAM to 1866, the PC would attempt to boot around 4 times... then fail to a BIOS message stating that booting had failed.
Yeah and JEDEC standard dictates that DDR3 must withstand up to 1.8v without incurring any permanent damage.
Agreed!Yeah and That ram should run 1866 9-10-9-27 without too much issue but that Giga board is likely the culprit. seen it before when trying to go above 2200 NB or increasing ram speed they take a lot of voltage for the CPUNB circuit to cooperate.
In most cases raising the Nb Freq for an every day system will help speed things up a lil. The difference, unless measured in some way, would most likely be unnoticeable. Though, if one is benchmarking, doing long hours upon end of rendering or computations, there could be a dramatic difference."must" "should" "if" if you know what i mean, just because you can doesn't mean you should in meh boards as you pointed out. Also if hes running 1600mhz there's no point to raising HTLink freq and CPU/NB freq above 2200mhz unless this is another set of ram with dodgy settings like the Fury or am i over thinking this ?
