Hey guys,
I just finished putting together my first WC build and thought I would share my worklog. Being a noob, I had much to learn and wanted to share my experiences so others could benefit! Here is my parts list:
Enclosures/Brackets:
Case: SilverStone "Temjin" TJ07B-W
3.5 Bays: SilverStone Aluminum 5.25-Inch to 3.5-Inch Converter CFP51B
2.5 Bay: Silverstone 3.5-Inch to 2.5-Inch Converter SDP08
NAS: Data Robotics Drobo FS DRDS2A21 (Max 10TB)
Radiator Stand: WCUK 240mm Radiator Stand WCUK240
Radiator Stand: WCUK 360mm Radiator Stand WCUK360
Storage:
SSD: 256GB Crucial RealSSD C300 2.5-inch SATA III/6GB/s
NAS HD: 3 x Seagate Barracuda LP ST32000542AS 2TB
Hardware:
CPU: Intel Core i7-930 Bloomfield 2.8GHz
Motherboard: ASUS Rampage III Extreme
Video Card: 2 x ASUS ENGTX480 (nVidia GTX 480)
Monitor: DELL ULTRASHARP 3008WFP 30 inch LCD
Memory: CORSAIR XMS3 12GB HX3X12G1600C9 (9-9-9-24)
Power Supply: Ultra X4 1200w 100% modular
Keyboard: Enermax Acrylux KB009W-B 2.4Ghz wireless
Mouse: Logitech Performance Mouse MX
Cooling:
CPU Block: Koolance CPU-360, Rev1.1
Video Block: 2 x Koolance VID-NX480 (GTX 480)
Reservoir: XSPC Acrylic Dual 5.25 Reservoir for Two Laing DDC's
Pumps: 2 x Swiftech MCP355 12 VDC
Radiator(CPU): Black Ice SR1 240
Radiator(VID): Black Ice SR1 360
Fans(Radiator): 5 x Noctua NF-P14 FLX (1200rpm, 65cfm, 19.6dB)
Fans(Case rear): 2 x Noctua 92mm NF-B9 (1600rpm, 39cfm, 17.6dB)
Fans(Case top, vanity): 2 x Silverstone 120mm Blue LED FAN FN121-BL (1200rpm, 53cfm, 26dB)
Fan (Extra): Silenx 80mm blue LED IXP-54-14B (this one actually doesn't suck)
Tubing: 15ft PrimoChill PrimoFlex Pro LRT Clear Tubing -1/2in. ID X 3/4in. OD
Fittings/Connectors/Nozzles:
Tube Nozzles: 12 x Koolance Nozzle, Compression NZL-V13-19KG [For ID: 13mm (1/2"); OD: 19mm (3/4")]
90 Degree Elbow: 4 x Koolance Fitting, Swiveling Elbow NZL-LXG1
45 Degree Elbow: 2 x Koolance Fitting, Swiveling 45-Degree NZL-DXG-V2
SLI Connector: Koolance Dual VID Connector, Adjustable 2-3 Slot Spacing CNT-VDA34
Adapter: Koolance Swiveling Coupling Adapter, Male-Male ADT-SMM
Nozzle - Koolance Nozzle Body, 4-Way Brass ADT-XUTX4
Tools:
Screw-driver set
Nut-driver set
Small "L-square"
Tape measure
Tube cutter
Small crescent wrench
Set of mini-files
Center punch
Drill
1/16" metal drill-bit
3/32" metal drill-bit
5/32" metal drill-bit
1" Bi-metal hole saw (drill-bit)
Small Arbor drill-bit (needed for the above hole saw)
Mini hack-saw
Nuts/Bolts/Misc:
Masking Tape
80mm Chrome Fan Grill
20 x 4mm-7 x 30mm Hex Head Bolt (radiator)
8 x #8-32 x 1/2" Round Head Slotted Bolt (radiator stands)
4 x #8-32 x 1-1/2" Round Head Slotted Bolt (extra fan)
12 x #8-32 Nylon Lock Nut
3 x 3/4" Neopreme Rubber Grommet
3 x 2->1 Y-cable (3-pin)
3->1 Y-Cable (3-pin)
ArticClean (1&2)
PT-Nuke
Distilled water
Arctic Silver 5 (TIM) - I now *know* I should have used another TIM /cry
Thats all!
I am still waiting on the Drobo FS (NAS) to arrive, it is back-ordered.
I had 3 major objectives with the build:
1) Minimal case modding as this was my first build.
2) Quiet computing (I value quiet over extreme low temps)
3) The ability to play current games in 2560 x 1600 with max settings and very good frame rate.
Hehe, so the first time I put it all together and leak tested, I had a leak (it was a loose fitting on a radiator). I took the build apart and made sure all the fittings were tight. When I put it back together, I made a few minor changes (like replacing some noisy Silenx fans, etc). However, I didn't always take new pictures...Next up, the pictures!
Storage:
Hardware:
Cooling:
Tools:
Screw-driver set
Nut-driver set
Small "L-square"
Tape measure
Tube cutter
Set of mini-files
Center punch
Drill
Mini hack-saw
Nuts/Bolts/Misc:
Masking Tape
ArticClean (1&2)
PT-Nuke
Distilled water
Thats all!
