Hi guys. I finally received the lst of the parts to finish my build. I ordered MOSFET, NB, and SB blocks from Anfi-tec because they are the only company that makes blocks for my board. Unfortunately the Monsoon fittings are too large a diameter to fit the NB and SB blocks. The center to center measurement between the holes is .710". does anyone know of fittings that will fit? Can I use barb fittings for hard tubing. I really don't want to use hose as it will mess up the look.
Thanks,
John
Thanks,
John
