- Aug 20, 2002
- Brooklyn, NY
Oh please…join right in!geoffman said:Guys I'm absolutely brand spanking new to water cooling and as yet I have to build a system, so tell me to butt out if you want
Yes, but also remember the concept of more mass. The amount of water you have in your system to do this job is not based on how much is in the tubes or reservoir, but on how much water flows past any given point in a set amount of time. When speaking of mass, gallons mean nothing and gallons per minute means everything.Ok, I can understand the bit about high flow rate being a good thing for a CPU water block (that seems pretty simple, faster flow means that means bigger delta of the coolant at the CPU's water block yes?)
Yes. But remember, it’s a combo deal. You can’t talk about the heat transfer rate without stating how much mass you’re talking about. A low delta, with more mass, can be okay. The only question is whether the rad can dissipate the heat.And I think I get what he is saying for radiator (low delta here is bad as the heat transfer is less?)
Yes. Well, you MAY need to increase the capacity. If you had the capacity to begin with, CPU temps will drop.If I have got this right it means that you need to increase your radiator's capacity if you increase your flow rate through it?
I think you have the general principle. The situation is not as bad as you described, because, once again, and like many people do, you forgot to account for increased mass. But that’s okay, as long as you got the basics.My logic is this…
So in this case we need a rad of twice the capacity when using high flows than that of low flows?
You actually are drawing more heat energy when you increase flow (and if everything else works out.) Some people argue with this, saying that the CPU is a constant heat source, and you can’t get more heat from it.
It is true that you cannot cause more heat to be generated by the CPU. However, heat transfer through the materials involved is not instantaneous, nor is it resistance free. The materials used do not allow 100% of the heat generated to be transferred to the water. The reason the CPU temperature is elevated is because some heat energy wasn’t removed by the cooling system. So, for every 100 watts of heat generated, there is actually a division of where the energy goes. For example (mind you, these numbers are being used because they’re easy, and are not indicative of actual wattage) say that 90 watts are being removed by the cooling system, with 10 watts remaining to heat the CPU to its current operating temperature. When you increase flow, and the rad has the capacity, 91 watts will be removed, and only 9 watts will remain to heat the CPU to it’s operating temperature. Hence, CPU temperature drops.
