Don't know if this will have any value to you but saw this t'other day.
http://www.techtransfer.anl.gov/techtour/nanofluids-summary.html
Sounds like it's a "go" for the methanol. I should be installing this coming week, I'll keep you posted. I might even do a few hours of running w/ only water and record the temps, then switch over to the methanol mixture and record temps again.
This, coupled with the previous points should be enough to make any non-blind, 'respiratory tract intact' person stop right there (Blind people with an already suspect respiratory tract, knock yourselves out). But wait, there's more!Inhalation : May cause respiratory tract irritation. May cause visual impairment and possible permanent blindness.
Really? And what effects might that be...May cause effects similar to those described for ingestion.
"Oh. That 'death' thing seems particularly nasty." Yes, it is. Even if you don't drink or inhale heavily there's always...May be fatal or cause blindness if swallowed. May cause irritation of the digestive tract. May cause kidney damage. May cause systemic toxicity with acidosis. May cause central nervous system depression, characterized by excitement, followed by headache, dizziness, drowsiness, and nausea. Advanced stages may cause collapse, unconsciousness, coma and possible death due to respiratory failure.
I don't need to reiterate what 'acute inhalation and ingestion' can lead to, do I? 'dermatitis' - I don't know what it is, but I know I don't want it!Prolonged or repeated skin contact may cause dermatitis. Chronic inhalation and ingestion may cause effects similar to those of acute inhalation and ingestion.
The ethenol/water mixture would have better heat tranfer and would have more viscosity. I think you should also take into account the thickness of the mixture once it's at those low temps.Ro said:A closed system is a good idea for both methanol and ethanol. Still, I'd much rather be cleaning up an ethanol leak than a methanol one.
Anyway I was thinking of using ethanol for my system. But given the data on this post, ethanol is worse at transfering heat than water. So what about some ethanol-water solution?
This site Colligative Properties: Freezing Point Depression and Molecular Weight seems to have some formulas for calculating what would give the optimum ratio. I want as much water in the solution as possible, without the solution freezing. I'm going to use a chest freezer for cooling the ethanol-water, so that means having enough ethanol to keep the freezing point below about -20c.
Or maybe I should be just looking for anti-freeze? I was betting on the ethanol, 'cause I thought it might allow for much lower temperatures. If I tamper with the freezer's termostat, will the freezer stay on and keep cooling down to -50c, or something? Or is it determined by the refridgerant in the freezer?
Later,
Ro
000 said:I've been wondering about the methanol toxicity question also. If you have an open system (which I imagine alot of the water chiller people do) is it really a wise thing to use?
Now about Ethanol:
Ethanol will keep the viscosity much lower than antifreeze, which will definately help pump it at -20c (antifreeze gets pretty thick at -20c), but Ethanol's heat transfer capabilities look to be poor.
Since Ethanol does have a lower freezing point you wouldn't have to use as much of it in a mixture of water to equal out Methanol, can anyone put some graphs up comparing a methanol-water vs ethanol-water vs antifreeze-water where they have freezing points at about -34 ? Ethanol seems like a much safer thing to use, just dunno how good it is.
Thanks,
-Sidney
sappo said:i bet if i increased the surface area inside a block by 5 times, i could use whatever liquid i wanted and it would still be better than water.
one more thing, water isn’t the best thing for liquid cooling. mercury is. its melting point is -40C and is almost 14X more conductive than water. it would be extremely difficult to use (although i still think its possible), but i think these qualities alone at least make mercury deserving of lip service.
eric
dmitriyaz said:r0ckstarbob,
sorry to take your time with this stupid question.
if i need the liquid to have good viscosity and thermal differential at -30 degrees, and i WILL NOT UNDER ANY CIRCUMSTANCES use methanol, wouldn't the best solution for me be ethanol/water mix?
antifreeze has extremely poor viscocity, it will eventually kill my pump. thermal differential of it is not the best, either.
distilled water-water wetter will freeze up.
well if ethanol water is not the best solution, what is?
and if it is, how come its not anywhere of your list?
thanks
