- Sep 7, 2001
- Seattle Washington
- Thread Starter
- #141
okay, um.... no.
listen man, i'm not trying to step all over you but you're bustin in here with both guns blazing when what you need to be doing is slowing down a tad and listen to whats being said. you're wrong and you're making contradicting or half formed statements based upon (i can only assume) partial information.
Originally posted by sappoAbout diamonds, you missed my point agian. It is 10x worse in thermal capacity and 10x better in conductivity. Yet they are vastly different in thier heat dissipating capabilities.[/i]
listen, your point is flawed. the reason diamond is such a good material to use for heat transfer is not because of one set of stats or another set, ITS THE COMBINATION OF STATS THAT MAKE IT GOOD. it's this combination of stats that is expressed as it's Thermal Differential.
You missed my point again. If you are going all out with all these toxic cooling mixtures, you had better make sure the block is extremely efficient, otherwise, its all for naught.
well, duh...
And about mercury, its about like lead. Handle it properly and it shouldnt be a problem. When soft, It is even ok to handle the dental filling material made from mercury, so long as you dont do it everyday. Good grief, pure Methanol has a flash point!
the puropse of this study was to look at polar coolants. yes it can be used with standard room-temp systems and yes there is a risk using a methanol based system. that risk is neglegable and with all things that we do in overclocking, the weights of the benefits must be weighed against the negatives when doing anything and then a personal choice must be made. if you're not comfortable using it, fine, don't use it. you don't have the data however to condemn its use because it's a perfectly viable solution with FAR LESS problems then using mercury. afterall, we're talking about a 30:70 ratio of methanol to water to get some really incredible performance. that is a pretty miniscule amount of methanol compared to the water. don't give me some crap about flash point at those ratios - it's not even an issue. nobody should even consider using better than a 40:60 ratio solution unless you plan to go past -50C! hA! fat chance.
personally, if you die because you couldn't put it together enough to handle windshieldwiper fluid without hurting yourself, you deserve to die. pure darwinian here, you deserve to die if windshield wiper fluid kills you (or blows up on you). and good riddance! improve the gene pool, cease to breed. eliminate stupidity through stupidity. it's a self consuming organism.
the idea of using mercury in a computer cooled system is not a good idea. in fact as an idea it sucks. it's utterly toxic, it's prohibitively expensive, it swells to extremes with heat, shrinks to extremes with cold... you couldn't even afford the equipment required to try and make something like that work in a computer system, much less to buy it in a quantity necessary for any kind of practical cooling use.
I think the best way to go is to use vodka. its cheap, has a low freezing point, has a low viscosity level, is nontoxic.... But most importantly, you can make white russians with it. Plus, its just plain cool to have vodka cooling computer!!! [/B]
i'm glad you think so. we're all entitled to our opinions. thank you for sharing your opinion. i'm sure you'll get adequate results and accomplish whatever it is you would like to accomplish.
The facts are that windshield wiper fluid is cheaper, doesn't have an age requirement to purchase, is not at risk of being drunk by your roommate, has a better viscosity level, has a vastly better thermal differential, has no sugars to screw up the works in your pump, and in addition to performing much much better, you can also find it at virtually any autoparts store. now granted it's not as cool as making white russians out of it, but my computer will outperform yours and won't be at risk of being consumed in some fratboy drinking frenzy....
... i can just picture it - shotgunning the computer like a beer bong, someone holding my antec over the face of some jock moron with a hose jammed in his pie hole with the rest of the room chanting "drink drink drink drink!" while my little enheim chugs away....
oh wait, i'm 26. i don't live in a dorm.
whew.
thems the stuff nightmares are made of boy i tell ya...
