- Sep 16, 2003
- Knoxville, TN
Its cheaper. Man's gotta make that dough somehowCunningLinguist said:I'm kinda puzzled how you would design one that didn't have the rails isolated from eachother.
Sentential said:Its cheaper. Man's gotta make that dough somehow
Oklahoma Wolf said:A single winding for one rail, and then buck regulate it down to the next needed voltage. This is how many older PSU designs are set up.
you are better off with a powerstream. I personally would go for the 520 or a 470CunningLinguist said:Hmmmmm Now I'm kinda tempted to buy a Powerstream. You think the 420W will cut it? I really wanted to go modular, but at least the powerstream has cable management.
Sentential said:you are better off with a powerstream. I personally would go for the 520 or a 470
100% incorrect. Fortron still has the most generous component selection, component quality, and build quality of any power supply short of a Zippy or PCP&C. Topower is competent, it is not Fortron build quality.Sentential said:That couldnt be further from the truth. In terms of quality OCZ is far better than Fortron. OCZ uses outsourced Topower PSU which are some of the best in the world next to PC Power And Cooling.
Nah...if thats the case, get the blue-storm. Its better than the 420WCunningLinguist said:UGH... a 470W is $30 more than I was planning to spend. Considering that the 420W peaks at 520W, I should be okay with it.
I belive I anwsered a similar reply in another thread. Im refering to the overall quality, not purely the hardware itself. THis is taking BTX and the pots and the customer service into consideration as well. Something Fortron lacks.larva said:100% incorrect. Fortron still has the most generous component selection, component quality, and build quality of any power supply short of a Zippy or PCP&C. Topower is competent, it is not Fortron build quality.
You were referring to features, not quality. Your remarks would be open to considerably less 'mis-understanding' if you said what you meant.Sentential said:I belive I anwsered a similar reply in another thread. Im refering to the overall quality, not purely the hardware itself. THis is taking BTX and the pots and the customer service into consideration as well. Something Fortron lacks.
However in this case, he is better off getting a Fortron since he cannot afford the nicer OCZs
Sentential said:Nah...if thats the case, get the blue-storm. Its better than the 420W
Exactally the arguement I poorly worded previously .larva said:I think either supply would please you. But for the sake of the record, and the users that might form purchasing opinions from it, OCZs have a really nice and well thought-out feature set, but Fortron is still the physical and electrical quality leader.
Sentential said:Well this will make **** nice and simple:
http://www.monarchcomputer.com/Merchant2/merchant.mv?Screen=PROD&Store_Code=M&Product_Code=100057
FSP = Fortron Source Power.
Get that. Nice and cheap and what you are looking for.
CunningLinguist said:You're right. The Fortron Blue storm is considerably better. I don't really need adjustable rails, and while isolated rails would probably be good, I don't really feel the need for it. A PSU with over 70% efficiency at minimum is pretty awesome. It's got cable management too, which is also a plus. I think I was really looking for quality over features, and this model sounds about right.
