- Jan 26, 2005
What slot is the gfx card in top or bottom?
Immortal_Hero said:Well it may have always been in the top slot but the default in bios for the primary card is the bottom slot on ASUS and most other boards. You will need to put your card in the bottom slot, boot into BIOS change your primary to the top slot ie PCIE2 and shut down and move the card to the bottom slot. -OR- get another PCI-E card, put it in the bottom slot, go into BIOS make the switch, shutdown, remove extra card and reboot. When you reset your BIOS it switched back to default.
WonderingSoul said:Just got home from the UPS store. 3day ground back to eVGA... Lets hope they don't notice the volt mod, I cleaned up really well though
WonderingSoul said:I cleaned it all up with 91%, I just used conductive pen so it came right off afterwords.
WonderingSoul said:Good thing there is no way to tie me to an individual card
Dan0512 said:I don't think you get the message.... you V-modded it, thus voiding the warranty.... so you shouldn't be sending it because you screwed it up.
dan
CrackerD|ce said:Well in doing this it shows a lack of strong ethics. However frustrating it is to lose a key component, don't try to **** companies out if you have a chance of blame landing on you. But whatever, I aint no eVGA cop, so hopefully it works with no conscience issues.
WonderingSoul said:Like I said earlier, the fried card was not from overvolting it. It was probably static shocked when handling it to put it into my new case. If it was fried from the overvolt then how could I fry it when it was sitting on my table not running ?.?
nvidiaOCmaster said:I don't know, but ive never statically damaged any of my hardware, and my video card id out almost every day, normally I sit it on my lap.
