CamH said:My first post!
Anywoo, I'm considering buying a mini fridge to stick my computer inside of. The computer's never off, so I don't think condensation will be a problem. (It's never been shut down for more time than is required to add more RAM since last summer) Of course, I'd still use silicon and baking soda.
What I'm worried about is the fridge itself. How well would it work, and how long would it last? Are there any ways to extend its life?
xX~EXCELSIOR~Xx said:
Well one thign is for sure make sure you have SOME type of even a passive heatsink on the cpu.
The fridge should last for quite a while
btw....
WELCOME TO THE FORUMS!!!
CamH said:
I'd certainly keep my CPU heatsink and fan. They're both oversized, but I forgot what they are (other than loud). For some reason, it still hangs around 60C, which I think is way too much. I'm gonna lap it later today, but I don't think that will do the trick as well as I would like, and I've got the money for a mini fridge.
Thanks. I think I'll be hanging around these forums. Seems like a nice place. [/QUOTE
Mhmm
The fan wouldnt be tooo neccessary since the fridge has air circulating.. but it sure couldnt hurt
http://www.oc-ware.com/reviews/607031.php
I suggest taht lapping kit that i just did a review of... its a really good kit that is cheap and it goes up to grits of 2000 ins andpaper and a 10000 grit compound.
there amay be more to your higher temps. what board do youh ave? It might be reading it wrong. You do use thermal paste correct? did you use too much? Starta new thread and tell us all about your rig and such and we will try to help you get that 60 degrees down
Laters,
Excelsior
CamH said:A fan wouldn't be needed? Excellent! That thing's loud.
Gonna run off and make another thread, as you suggested.
CamH said:I've got a little over a hundred dollars set to the side now. I'm on the hunt for a good mini fridge!
