mycotopian said:I had to regulate humidity in a growing experiment once and a cheap and easy way to use this stuff from any garden supply store called vermiculite or perlite. just put a tray in the bottom of the fridge and voila humidity drops. Ibeleive the tool to measure is called a hygrometer you might want to stick one in the fride and cut a plexi window so you can watch it.
SpaceRangerJoe said:man, this thread just wont die!!
hehe.
SpaceRangerJoe said:*cough* look in classifieds *cough*
I agree you should put insolated glass window in it to see runPlanus said:So long as the door is sealed tight and you dont keep opening the door, you ont get condensation (but it needs to be airtight (like where the wires go in) Theres no reason why condensation should form, I mean all your doing is changing the ambient temperature. I mean it diesnt occur when your MOBO is in normal room temp, so no reason (unless warm air leaks in) why you should have any condensation problems
You want the fridge hot and no humidity when you put the mother board in it and then seal itCamH said:Well, water is let even when you open the door to just put the computer in. That's why there was only a little bit of ice on the back and not a whole load of it - it could only freeze the water that was there. Water is in the air.
