- Mar 4, 2004
- San Diego, CA
i went to finally start some oc and found my temps to be idle at 50 / load 80. sure enough my heatsink (dtek v1 w/ 1366 bracket ) wasnt touching the cpu since there was barely any paste on it. i try to press it down and it just isnt able to sit on the cpu. i have yet to take out the board to check better, but im guessing the hex bolts are getting in the way since they stick out farther then the base and hit the large metal cpu bracket. just wondering if this is a known problem or am i being a retard. .. maybe butting a thin piece of copper in between would be the fix / what about foil like a laptop often has... or ill just go for the gtz because im worried id have a similar problem with the v2
