Hey guys,
I'm at the point of giving up on attempting to overclock this chip. Right now I'm at auto / default Voltage / Multiplier / except for the power saving features are DISABLED. I'm running 4.2GHZ (4.3GHZ TURBO)
I ran P95 for about 10 minutes and no errors.
First and formost, here are my specs:
CPU: AMD FX 4170
Cooler: CM hyper 212 evo (2 fans (push-pull)
RAM: G.Skill ARES 8gb x 2 (16gb) 1866mhz
MB: Asus Sabertooth 990fx (Rev.1.0 if i remember correctly) (bios: 1604)
hdd: SSD 120
VIDEO: Radeon HD 7870 Ghz Edition
PSU: 500w (using 184w per my batterybackup)
What led to put it back to stock:
I've put about 8-10 hours on this.
Last night I had a 4.5GHZ overclock running for about 6-12 Hours, stable.
Operated the computer normally, websites/gaming etc.
If I remember correctly, the settings I had were 22.5 Multiplier (FSB:200) Voltage 1.41
PLOT:
Around 12 midnight, I was attacked by my house cat and in the terror, the cat grabbed my Headset, the wire tugged on one of my speakers and other stuff on my desk, which had a full plastic cup of water, and violently shook my CASE From what I saw, the water went on the front of my case and top but I didnt see any go in... But on the front it probably hit USB/power switch. I cleaned the water off and didn't think anything of it. 5 min later, while watching a movie, notification says I recently plugged in a USB device and it's not functioning. I ignore it, 3 hours later, it blue screens and doesn't POST. I troubleshoot and find out my CPU is not passing post. (cpu_led) is red. So i find it a forum post that says it could be uneven power..skip to this morning.
So my machine not posting and having major issues with power. I replaced my power supply, reset my RAM and CPU (reapplied arctic silver 5 (grain of rice method), boot, pass post, reset to defaults, (This was probably after about 15 boot attempts) and I am stable now.
So now that you know the machine may have been compromised after last night, what would you recommend to test the overclock-ability of this chip at this point.
I am a novice overclocker. I understand some concepts of it.
Voltage powers the chip
Not enough will blue screen (Ive seen ALOT of those)
My chip seems to run at the very least at 1.34 / 1.35V stock.
More voltage more heat, more multiplier (more clock speed) which requires more voltage to keep it doing it's CPU things, yada yada yada. (i hate that phrase)
So I leave it to you to see if this is worth it to experiment with a bit more, or save up for another chip?
For my work with this chip, even at default operation, I've had some blue screens since I've had this build. (Of course there is a question to if my PSU was unhealthy).
If I need to get more info, I'll be glad to.
Here's what is right now!!:
-clay
failclocker
CPU: AMD FX 4170
hdd: SSD 120
PLOT:
-clay
failclocker
