Thank you for that, will update asap.
Btw, Johan, that Guide helped tremendously. I did a moderate overclock of the CPU, I am stable at 4.69 Ghz. I had no idea about the 2 Northbridges on AMD Bulldozer..
I don't want to go too high at the moment, without monitoring my temps for a bit. I'm still in the break in period for my arctic silver.
I'm thinking about posting a few screenshots of the ASUS UEFI Bios for overclockers that have the Sabertooth.. Might help, make my own guide.
Thanks again
RGONE, would having my CPU_NB at 2500+mhz and set to. 1.27Ghz cause a crash, I'll let you know of my symptom that started last night:
So I started crashing last night after a reboot attempt on my machine.
I'm starting to think that it's something to do with the chip, possibly a lemon or an issue related in this post, although old:
http://scalibq.wordpress.com/2011/10/19/amd-bulldozer-can-it-get-even-worse/
This is the symptom:
- I rebooted after installing software.
- After windows login, looking at my Windows Gadgets, I notice one of the Cores (CORE 1) sticks at 100% while my system loads, the CPU obviously being heavily utilized. It never goes down to below 100% and 5-15 seconds later, blue screen.
NOTE: This is not a new problem. This has happened before but I didn't think it was a seperate issue until now, becuase I think my voltages are fine.
- Thinking it was a voltage problem, I uped the voltage on my CPU and CPU_NB by .01 CPU 1.38 and CPU_NB 1.28
After reboot, it still crashed but it crashed when CORE 2 went to 100% for about 10 seconds.
- I set it back to previous settings becuase prior, it was running for almost 24hrs or so at 4.7GHZ. Rebooted, and still same thing happened with another core (Core 1)
- Skip to this morning. I booted the system and it started stable. No crash. I did see your post and prior to this set the CPU_NB frequency to 2200. It was set to 2500Mhz.
The HT Frequency is 2500mhz and change.
I'll keep it like this for a time and see what it brings me. I am now running BOINC on it so I'll see if anything should happen today while that runs.
