- Jul 14, 2013
- Holed up in Branford, CT
I rarely read anything good about MSI boards in overclocking forums. Granted I just read AMD related threads.
My GA-990XA-UD3 Rev. 1.1 works fine with my 8320 at 4200 MHz. It isn't in the same league as a Sabertooth Gen. 3 R2 for overclocking but it gets the job done.
Don't buy an MSI motherboard for this application. There's a reason their prices are low.
You're right, but it also isn't in the same price league.
+1. Haven't seen an MSI board truly stable with FX on these forums.
I would be very careful when buying a Gigabyte AMD AMD+ mobo; that you know exactly what revision of motherboard you are getting. It makes a BIG difference in your sanity when trying to do an overclock.
GA-990FXA-UD3 (rev. 4.0) http://www.newegg.com/Product/Product.aspx?Item=N82E16813128514
Bassnut a regular in this AMD forum section has made a minimal trial of the GA-990FXA-UD3 (rev. 4.0).
GA-970A-UD3P (rev. 1.0) http://www.newegg.com/Product/Product.aspx?Item=N82E16813128651
The GA-970A-UD3P (rev. 1.0) board seems, when looking at gigabut site, to be the replacement for the GA-970A-UD3 Rev 3.0 board.
The thing I don't like is having to buy into a revision of a board.....
So I'd like to ask you if there's motherboards that could be suggested that never had a revision or where fine as is?
Or does it seem to me like almost all the boards now a days are getting so called revisions instead of new style boards being produced?
Even the Sabertooth has issues with some of its revisions.
Boards have always gotten revised over time.
I'll warn you now, it gets addictive.Apparently no microATX boards will do...GA-970A-UD3P (rev. 1.0) is a solid choice which i can get for 90 Euros in my country.Thanks for all your replies!I have sunk a bit deeper in OCing world with your help!
So I'd like to ask you if there's motherboards that could be suggested that never had a revision or where (SP were) fine as is?
But the question was could you buy an AM3+ mobo and have it work and yes it was the Asus Sabertooth 990FX
I like the Asrock 990FX Extreme9 it will get my FX-6300 to 5.4GHz quite easily.
Yeah it's a solid board for the money.Heck yes it will.
RGone...
Heck yes it will.
RGone...
