Hey mates,
I have the following hardware:
My first attempt if OC was via the AMD Overdrive in Cataclyst, but thats not the best as i heard so i switched back to stock values.
The second attempt was via BIOS. I bumped the Multiplier to 20 (4GHz) and tried a Stresstest in Prime95. That runned nice for ~20 min, so i decided to start Furmark aswell to check the max. heat generation. But ~20 seconds after the start of Furmark my screen turned black and the pc went off. Pushing the restart button wont boot it up, until i unplugged/plugged the AC-plug. It that normal?
So now i need help how to get the best out of my system for 24/7 use.
Which further information do you need ?
The best helper will get a beer. Paypal only.
- Gigabyte GA990FXA UD3 rev.1.2 (latest beta bios)
- AMD FX-8120
- Arctic Freezer xtreme Rev 2.0
- AMD HD7970
- 16 GB G.Skill RipJawsZ C3-14900U CL9-10-9-28 1866MHz
- be quiet! PURE POWER CM BQT L8-CM-730W
- Lian Li PC 7FN
- Win 8.1
