What exactly do you mean, I'm little confused by the question?Also, what about the volts? Is there anything I need to change in bios?
I didn't want to know what their stock settings were I wanted to know what the Nb Freq, Ht Link and Ram were running at when you upped the FSB.
Do you still have the Cpu V core on auto? You are better off setting it manually, that way you can better tame the heat. Auto will usually overshoot what you will really need.
Also I would only run 2 of the 4 g pny sticks and make sure their timings are set correctly according to their Jedec profiles in the cpu-z spd tab, for the frequency you are running them at. You may not have had issues running day to day but that and running prime are two completely different ballgames. We want to remove any possible faults for errors before we really try pushing that chip.
That's just what it was set at auto. Yea it's stable at 4.3.
I noticed a post about going 220x20 would increase performance more than just raising the multi up.
I tried 220x20 raising vcore up 3 notches and CPU/NB up 1 notch but wasn't stable in p95.
Got illegal sumout soon as I ran it.
