When I set the volts to 1.450 it turns Yellow. Is that ok?
4.4ghz stable at 1.464 volts
75c CPU Temp
53c Package Temp
Think I'm gonna back down to 4.0 until I go custom water loop.
Desync,
It's time you created a "Sig" with system component information so that it travels with every post you make. This is a common forum courtesy. Go to Quick Links at the top of the page and Edit Signature.
Desync, unfortunately these processors run HOT when overclocked. Putting a fan behind the motherboard socket will help that temp get under control a bit more, your choice obviously.
If you think yellow is bad you should see what happens when you get over 1.6
Another things to keep in mind, if you do choose to go full custom loop, you will probably need less Vcore to run the same overclocks. I need 1.46 to run 4.7. Which is what I run 24/7 my temps max at 47 cpu socket and 40 on the cores, with the loop in my sig.
Now that was effin funny RGoneYou should have seen it when I put the Fatal1ty to 1.71 Vcore to get that 5.5Ghz CPUz validation for C_D.
Flashing Blue...I got my license out since it had to be the Vcore Police. Hehehe.
RGone...
Pink then Purple. Looks like a bag of skittles.
Yea I overclocked it to 4.0 a few months ago. Currently don't have Internet at my new house so been posting from my phone.
All I did was up my multiplier to 20
It's stable at 4.0 and I get very good temps from it.
I just need to figure out what all to set to manual and what their stock settings are.
My current CPU Vcore is at 1.320
You are correct on my parts.
I been looking at the G.Skill Sniper 1866 ram. Thought about grabbing 16gb of that.
Also might sell my 8120 and get an 8350.
If I were you I would get the DDR1866 ram first and try that FX-8120 with good fast ram. The reason I say that is the FX-8120 and good fast ram will do pretty good and maybe to about 4.4Ghz. Beyond that the mini-closed loop cooler you have will not allow much faster anyway. So you buy a good FX-8350 and are hung at 4.4Ghz due to not enough cooling and then comes another purchase for better cooling just to chase a little more performance.
RGone...
