- May 18, 2012
First, check to see that you have BIOS that is up to date for your board (*** ignore as my typo*** ---> version 1402). If not, the temp being reported in BIOS may be different than what HWMonitor would display. HWMonitor will display a more accurate number, unless you have BIOS 1402 - then BIOS and HWMonitor should read the same (if you could view both at the same time).
If you didn't check your CPU to see if it is a high leakage chip, either check it to see or keep your Core temps below 55C under load (reasonably safe thing).
Then, read post #15 in this thread.
If you want to read about my recent overclock safari with the setup in my sig and the help trents gave me, just click this link: http://www.overclockers.com/forums/showthread.php?t=708295
