AMD FX-8120 @ 4.22 GHz (1.272 V) = is that speed tested to be stable for at least 2 hours using Prime 95 in Blend mode?
RGone...
If you have a golden 8120, a 8350 is not an upgrade, and the OC method is the same for both, so not much extra fun.
I'd squeeze this 8120
I think you'll find the power consumption will actually go up.
F***. I thought Vishera draws less power? Atleast on some tests, 8150 vs 8350 (clock to clock) Vishera has much impoved power consumption.
I was thinking of buying FX-8350 to play with on easter. Is it worth upgading from 8120, I currently run it at 4.2 GHz with Noctua NH-D14 as stable 24/7 OC. How far does 8350 approximately go on air?
Bigblue, what you should do for starters is start a new thread with that question, it is not proper etiquette to hijack another post. You would also need to list the specs of your system, including the make and model of your PSU. These 8350's draw a lot of power from the VRM sections of a motherboard. Most users who are un-educated about overclocking do not realize that just because a motherboard say it can overclock a cpu doesn't mean it will OC one of these FX 8xxx series chips very far or at all. After we have the specs of your system, determining what Cpu Heatsink is best for you, can be made.Hello everyone just joined and I have questions. Freshly upgraded and everything is stock right now. I learning about overclocking and I need to upgrade the cooler first.
I need to know what the best OC speed I could hope to see with my new 8350 is with the best air cooled heat sink.
Please let me know what heat sink that would be.
What's the best I could expect with water cooling.
The new cooler must look cool. lol
