- Thread Starter
- #21
This 8350 has VID 1.375 V, would be perfect for extreme clocks with watercooling, or was it just the opposite?
4.4 goes with 1.375 V, 4.6 takes 1.450 but sadly that's the limit for my NH-D14. Did blend only couple of hours though.
gotta try that. Someone offered me 130 € for my 8120 so the price of upgrade isn't really that bad.
I usually dont push over 60c core just because i have no need to push it that hard. How far you can go on air really depends on the chip and how thirsty it is. I can do around 4.9 give or take when i had my noctua on it, at 1.52vcore and i was running 62-64c after an hour with 18.3c room temp and good case airflow. With my 8320 i couldnt do over 4.5 without dumping 1.55 into it.
As for is it an upgrade? Yes
Is it worth it? No, unless the 8120 isnt providing the performance you need. Piledriver will give you a bit better performance but isnt worth the price to upgrade. Wait for steamroller to come and see some benches on that to see how much better it is..
In the mean time, to keep the itch away, start playing with some benches and see what that chip can do! Whenever I feel like building a new rig or swapping to something different, I just load up Superpi or something and take it out on the poor 8350. If it goes up in flames its time to upgrade! I think it likes it though as it always begs for more.
