- Dec 19, 2012
- Thread Starter
- #21
I have to agree with you Rgone. I've reached the ceiling for this chip.
Just for sh*ts and giggles and my own curiosity I pulled the rad outside of the box and set it up as though it was mounted in the top. Horizontal with the heatsink well below it and made sure the air wasn't restricted to it.
Didn't make one bit of difference. Still hitting 54C.
That small fan on the back did bring the socket temp down to about 8 deg above the core where it was almost 20 before and causing me to abort testing. I wasn't able to let the core get up to temp.
I'm still tweaking a bit I've bumped up my HT to 260 and lowered the multi to 17.5 which has allowed me to drop the volts a tad and gain a few Mhz to 4565. Still ~ the same temps
When finished I'll probably settle for 4450 ish to keep things safe. I do know that when that vid card gets going it'll heat the board up as well cause I do some BD ripping with DVDFAB which will use the card and CPU to the max.
Thanks a lot guys
You've been a lot of help
Thanks a lot guys
