Yeah that phone thing. I wish the forum would post note at bottom when from and iphone or whatever instead of leaving us to wonder. Oh well. Sorry man your sig when showing is pretty darn elegant.
Well it is certain you can lower CPU_NB speed some and get a little Vcore relief but you will give away a little performance and can get slow enough the ram does not have a fast enough buss to talk to cpu over.
My FX-8350 seems to run just a little cooler than my FX-8120 did but it is nothing to write home about.
Have you looked in 'ssjwizards' thread comparing his FX-8120 vs his FX-8320? You probaby should since many of us found the sweet spot for BD 8 cores was about 4.3Ghz and everything above that was some slight extra performance with a hefty penalty of the added need of Vcore and temps that were rediculous for the small performance gain in doing work.
I did some looking into overclocking my CHV at rog and found one memory timing that I could change and then I could run my Gskil DDR1866 at tight timings and DDR1866 or higher and run 4.3Ghz @ only 1.38Vcore and most likely at that speed could have cooled the CPU 24/7 in a good case with a CM 212 EVO. I don't have the CM 212 EVO to do that test but my temps were oh so much better when I left off my 4.8Ghz speed and dropped to the more economical and sweet spot for performance of 4.3Ghz.
Leaving my fixation with high cpu speeds on the FX-8120 made my life oh so much more enjoyable with computing. Right now my FX-8350 is running 4.5Ghz at the very same settings for ram and all that I used with the FX-8120 and I do not have nearly the temps nor need more than that 1.38Vcore. Again what a relief.
I don't game much but if i did, I have thought about what I would do with FX-8350 I have now and am pretty sure I would go into bios and Disable 2 modules to get rid of heat rise and might bump my cpu speed up a little more then but with 2 modules Disabled for gaming, the heat should still be managable. We used to disable Intel Hyperthreading to push cpu speed back when I was using Intel to push the CPU speed but keep temps lowered.
I think testing and thinking outside the box based on how few games can use all cores anyway, is perhaps the domain of a more pleasurable experience. I have enough cooling for my FX-8350 to run the hot 5.0Ghz numbers but find 4.5Ghz much more rewarding overall. And after another round of tests with the FX-8350 with rendering my self-made videos, I may drop the 8350 to the same 4.3Ghz of the 8120 and am guessing the temps will fall again like a rock. More testing is in the offing for sure.
Good luck man and hope you find a managable config that is more a pleasure to use.
RGone...ster. ______________
