- Jan 12, 2012
What Johan is saying is, when you change the FSB to overclock you are also changing the HT Link, NB Frequency and Dram Frequency. So you need to keep an eye on those, because, especially with the Dram, they can cause instability as well. I usually link my Ht Link and NB frequency together, meaning I'll run them both at the same speed. I usually have them between 2400 and 2600 depending on the FSB I'm using. You may need to increase the Cpu NB V but that will add heat to the system. As far as your Dram these processors can handle higher speeds but you may have to start messing with the timings on them to keep the system stable.
