- Dec 16, 2013
- South Texas
- Thread Starter
- #21
Ok think I got it
Ok so after much research and hearing how the newer 8350's did not seem to be performing as well as the earlier versions Actually some of the later FX-8350s are doing much better. Clocks upwards of 5.0Ghz on plain water stable for 2 hours of P95 Blend.
in the meantime do you guys think an h100i would be able to handle the 9590 at stock settings?? until I can get a custom loop on it? I ask because I already have one that I bought on sale awhile back thinking to use it when I upgraded my CPU but from what I've since learned I know it's not going to handle OC'ing a 9590.
only board I know to support this chip properly is the ASROCK EXTREME BOARD
THIS^^^^^^^I know for a fact that the Sabertooth and CHV-z will support them just fine!
The Gigabyte 990FX-UD7 should be fine, too. They certainly have the power section for it. And my UD3 Rev 1.0 got lucky and supports my 8320 with a BIOS upgrade.
We can tell you first hand that it will work on the Sabertooth and CHV/Z. There are a bunch of us running our Fx 83xx's at Fx 9xxx speeds, that is also with all 8 cores enabled, and those two boards as well as the Asrock board will work. We also have a couple of members that have a Fx 9xxx cpu and use it on both the Sabertooth and CHV-Z without issue.asrock extreme 9 990fx board , as far as I know is the only board certified to support the 220 watts needed.
http://www.asrock.com/mb/AMD/990FX Extreme9/index.us.asp
look here , supports the 5g
