- Feb 11, 2006
I havent built new gaming rig for 6 years. I figure its time to upgrade. What does everyone here suggest for components? It'd be air cooled. Thanks for the help.
Do you want to be able to overclock it?
Do you need an OS?
What Screen resolutions do you plan on playing at?
Do you want all the "eye candy" at high settings?
Do you have one near?If you have a Micro Center near by your money will go a lot further
Ok that would have helped a bit. After MIR a little less then 1k.about an hour away
Hi. Given the suggested components and just 1080 res with no OC, what's a good suggestion for the casing and RAM?
