Hey guys, was searching around for a site that could give some advice and here i am!
-Build-
Case: Currently I am running off a workstation based case without a top or a side panel sitting on my desk.
CPU: 3930k stock speeds
CPU Cooler: Corsair H80
RAM: 16gb at 1600mhz
GPU: 2x EVGA 580 3GB SLI (6 total if i can add)
Mobo: Sabertooth x79
Fans: Stock Corsair fans with the radiator(push/pull config) running at around 2200rpm (i think :/) on the medium setting. And 1 extra 120mm blowing on my second 580 which seems useless.
First question: Are my idle temps/load temps alright?
Ambient temp - 23-27c
Here's a screenshot of my temps at idle after a boot for almost 30min
Now when i run prime95 on the maximum heat test my temps will almost instantly shoot up to around 63-70c. Is this normal? or am i being unrealistic because im running that "maximum heat" type of scenario? Basically i want to know if i can easily get 4ghz very safely and how to do it. I've read through some of the SB overclocking guides and they just go too in depth and past my knowledge. All i want is that 4ghz Should i ditch the H80 for a nicer air cooler? Im not used to how hot these run i guess! Let me know if you want any more info! Id appreciate the help
-Thanks, Conor
-Build-
-Thanks, Conor
