- Sep 13, 2011
I previously purchased this kit of ram in early 2010: http://www.newegg.com/Product/Product.aspx?Item=N82E16820211409
Then about 4 months ago i purchased this one: http://www.newegg.com/Product/Product.aspx?Item=N82E16820211457
so now i have a total of 12 GB which are running in dual channel. the problem is, I used to be able to run the 4 GB kit at 1600mhz at 8-8-8-20-25-1T timings just fine with no stability issues. After adding the extra 8 GB (all 4 slots are filled), they won't run at 1600mhz even at stock timings 9-9-24 with 2T. I've fiddled with the northbridge frequency and memory voltage but no matter what I do, I still get constant bsod's or lockups. Currently the last 4 months I've been running them at 1333mhz at 7-7-6-18-33-1T without issues but I would really like to try and get them at the rated speed again. I definitely noticed smoother frame rates (less jerky) in games at the higher bandwidth. I also have a fan blowing on the ram chips but that didn't fix the problem either. I'm running a phenom 2 955 C3 at 3.4 GHz at 1.275Vcore with the stock cooler with no issues with that (stock voltage makes it run at 65C, so I had to decrease the vcore a lot)
My current specs are:
phenom 2 955 be c3 @ 3.4ghz 1.275V
Asus m4a89gtd pro
zotac geforce gtx 560 ti amp! edition
auzentech prelude 7.1
750GB seagate+320 GB seagate in raid 0
coolermaster haf 932
windows server 2008 r2
ps: how much difference is there in 1T vs 2T. also, my bios has the option to change CPU/NB voltage, NB Voltage, and NB 1.8 Voltage, SB voltage, along with VCORE. not sure which ones to change
Asus m4a89gtd pro
