Hey guys, I got the upgrade fever again and since most of my parts are pretty much maxed out, I'm turning to the cooling system. I find my current kit a bit too loud for my taste so I'd like to dabble into watercooling again. Now I'm not a total newb, I did have a custom build 7-8 years ago and it worked really well for almost 5 years (until my landlord screwed up the transformer and blew up my 2 psus and my mobo).
I must admit I'm a bit out of the loop (bad pun not intended) hardware wise. I doubt most of my old components are still usable (not properly stored, incompatible blah blah blah) so I'll buy everything new, difference is this time I actually have a decent budget haha.
Ok the system I want to cool is in my sig but I'll repeat it anyway :
Core i7 3770k OC'ed (max freq will be determined after retesting with new cooling system)
ASUS Sabertooth Z77 (won't be cooling the chipset or anything like that)
2x EVGA GTX670 Superclocked 4GB (those fans are annoying)
Current case : Fractal Design Define XL (R1)
Current PSU : Corsair HX1000
Current CPU cooler : Corsair H80 with 2x Gentle Typhoon
Current Case fans : a mix of Noctua NF-P12 (2 in front, 1 at the bottom, 1 in the side door, have a few more spares) and NF-P14 (2 in front) and that weird angled fan at the top of the case.
Now I'm seriously considering changing the case/psu (won't be wasted I have a few motherboard+cpus laying around that need a case/psu) because the define XL R1 wasn't really designed for water cooling.
I'm thinking about getting the Fractal Design Define XL R2, yes it's pretty much the same thing but it can support a slim 2x120mm rad above the mobo and another 2x120mm (not necessarily slim) in front. And since I'm a bit lazy I'd buy a new PSU (probably a corsair HX1050) to keep my current cable management intact (besides, secondary/tertiary computer would need a psu anyway).
As for the cooling itself, I was thinking about making a dual loop internal system. 1 loop for the cpu, 1 loop for the 2 GPUs. As far as I can tell, it's not recommended to run 1 cpu + 2 gpu in a single loop.
Now the shopping list :
- Fractal Design Define XL R2
- Corsair HX1050
- EK GeForce 670 GTX VGA Liquid Cooling Block - Acetal CSQ (EK-FC670 GTX Acetal CSQ)
- EK FC Bridge Dual Serial 3-Slot CSQ - SLI Connection - Acetal (EK-FC Bridge DUAL Serial 3-Slot CSQ)
- EK Supremacy ELITE CPU Liquid Cooling Block - Full Nickel - Socket 115x w/ Indigo Xtreme (EK-Supremacy Elite - Intel 115x)
- XSPC RX240 Dual 120mm Radiator - Custom Painted White (for the front)
- XSPC EX240 Dual 120mm Low Profile Split Fin Radiator - Custom Painted White (for the top)
- Monsoon compression fitting 1/2" ID x 3/4" OD (3 packs of 6)
- 2 killcoils
- PrimoChill PrimoFlex Advanced LRT Tubing 1/2"ID x 3/4" OD (probably 20ft to have a bit of spare)
- XSPC Dual 5.25" Bay - DDC Dual Pump / Dual Split Reservoirs w/ Dual Pumps Installed (2x MCP35X)
I'm in Canada so my suppliers are limited. I'd rather get most of my stuff from Canadian suppliers like NCIX but most of this stuff isn't available there (like the gpu blocks and the rad). I know FrozenCPU ships over here (I bought from them a few years back) but it's gonna be rather expensive.
At this point, my total cost including shipping, taxes, duties, etc. is probably around 1.5k so I'm definitely open to suggestions but that's a bit more than I expected to be spending.
For the fans I'm undecided at this point, might get more Gentle Typhoon or use my current Noctua. If I'm REALLY desperate I have a dozen Delta AFB1212VHE monsters from my previous build but I'm aiming for silence (well as much as possible).
So yeah, feel free to comment, I'm open to suggestions. Maybe I'm missing something, maybe I went completely overkill on one aspect or the other (I tend to do that).
Thanks in advance,
Dak.
- Corsair HX1050
- 2 killcoils
Thanks in advance,
Dak.
