- Sep 15, 2007
- Small town Emlenton, PA
A 120 rad adds very little restriction in comparison to a block etc. do it if you want to one 35x is fine.
Ok quick update. I found a new supplier who has most of the stuff I was looking for at approximately the same price than the us supplier, so I'd save a lot of money and possible issues with customs by going that route.
Now I have 4 small problems :
1) Their res selection is rather limited, they pretty much only have XSPC so I'd end up with the split res with 2 pump mounts I started with or I can get the Maelstrom from NCIX but it ends up a bit more expensive.
Go with what you believe you want. Its not up to us but up to you. Peronally I'd get either or but would slant a little more with switech's reservior.
2) Their pump selection is abysmal, they don't have most of the "normal" brands. They seem to rebrand Laing pumps themselves. I'm guessing this is the closest to the MCP35X:
https://www.dazmode.com/store/product/dazmode_storm_ddc_3_2_pwm_18w_pump/
Its close enough. Thats basically the MCP-355 modified with PWM. Thats right behind the MCP-35x with out the top. You could go with that pump and grab the - MCP-35x Top - but you'd have to look around to see if they have it at your local stores/sites. If you're going with the XSPC reservoirs here are some good choices - Single Pump Res. - - Dual Pump Res. -
With those you can plant the MCP-355s or any DDC pump really.
Heres a Martin review of a - MCP-355 - with different tops.
Unfortunetly the price on those older pumps seem to be pretty close to the price in the states for a 35x. Choose wisely and with your pocket or let loose. Up to you.
I can't use those 3/8 barbs with my tubes so I'd have to go with a custom top, how about this one? https://www.dazmode.com/store/product/ek-ddc_x-top_csq_-_acetal/
That top is good but if you're mounting the pump(s) to the reservoirs you won't need these tops. Thats also if you get the Maelstrom with the single or dual top.
Alternative pump (not pwm ) http://www.ncix.com/products/?sku=20141&vpn=MCP355&manufacture=Swiftech&promoid=1294
3) The reservoirs I selected where custom painted white by FrozenCPU, this new supplier has the same models but only in black. This is not really a question, just pointing out that it's gonna have an impact on the theme I had in mind and I need to think about it. Price wise, the black versions are around $20 cheaper (and from a "local" supplier)
No worries. You can rethink the whole theme and make adjustments. Sometimes you need to compromise from your original plan to move forward. It happens to the best of us.
4) There seems to be a bit of a controversy about killcoils and nickel plated blocks/fittings. EK apparently voids the warranty if you use killcoils. Should I revert to pure copper or consider an alternative biocide/corrosion blocker?
Some guys can throw some insight on the arguement about that. Some folks were upset with EK if I recall correctly in the past with the whole flaking issues.
I'd use the killcoil and don't bother with EK.
On the bright side, they have reasonably priced Bitspower compression fittings so I think I'll grab those instead. Not the same look than the chrome/carbon fiber monsoon I was gonna use but basic black should work well enough.
If the pump is "good enough" and I drop the killcoil, I may avoid ordering from the states.
Even better and you'll save more $$$ or you can take that and add it to the build.
Get a tube res. 150 mm tall minimum. They bleed easier and are so much easier to fill. Bay reses are a pain. As you have been reading about. Or read what I used on my two DDC 3.2 below.
That's a standard Laing 3.2 DDC pump with the stock top. Pretty decent. Enuff for your loop. It's not PWM, or having the custom (very well done top by Swiftech) But you can voltage control it, my 3.2's were pretty quiet with the XSPC restop on them.
And you get standard G 1/4 threads.
This is the restop without the pump.
Find me pics on this top, Daz is lazy.
You never tell them, they will never know. Even Swiftech has a warrenty disclaimer about the Hydrix they sell with a premade loop. It's to protect them from stoopid people, your not one of them. Use Petras PHN Nuke. Or IANH Dead water, or Mayhems biocide. You look at the price of the liquids vs distilled? Remember we recommend you drain/refill every 6 months. I drain, fill, run for a day, drain again and fill every 6 months. Since I use killcoils and PHN, it probably costs me ... wait for it... $3. Now you look at 2-3 liters every 6 months with the magic fluid. $$$
Bee ohh so careful, to the point of putting something on your pliers/wrench etc. They scratch and the plating is thinner than the hair on my head.
Yeah, I'm checking out the possibility of painting acetal, if that's possible then I'll simply grab the black rads and paint everything (rads, cpu block, gpu block, sli bridge). Of course I'd take all the necessary precautions. It'd fit the theme even better because right now... black case, black motherboard, black cpu block, black ram, black vid cards, we wouldn't see much.
For the pump, I also found this one : https://www.dazmode.com/store/product/dazmode_storm_ddc_3_25_18w_pump/
It looks like a 3.25 version, like a 35X but cheaper and no mention of PWM, that's kinda weird, right?
Nope, bit better than the 3.2. Been out for a few years. You ever use Martin or Skinnee for reads? I think they tested it. Basically the same, neither is PWM. Swiftech is the one who had Laing make a PWM pump for them, the 35x, and the engineer at Swiftech made an awrsome top for the pump for flow/pressure. Alll Laing did is make the pump and the impeller, Swiftech makes the top. It's the first PWM. They also contracted Laing for a PWM d5. A D5 is a MCP 655. A 355 is a 3.25 all the same stuff. Swiftech took it up a notch and made their own top for the 35x. And it's a winner winner chciken dinner.
I did read the review, I was simply checking what you guys thought of the "rebranding" which is more like a debranding because it's a simple Laing pump with no visible modifications.
There are 2-5 companies that buy Laing pumps and rebrand, even Danger Den did it, Alas, they are closed, I have met the DD guys in RL, great folks. Well is as Gabe from Swiftech.. Glad you haven't got a laugh at the Koolance site yet.
I did find the MCP-35X top but it's like $25 and it won't add pwm (obviously) so I end up with a slightly inferior product at a higher price.
For the res, yeah I was looking at the dual pump res, that's what I meant with the "split res with 2 pump mounts"
As I said, I'd need to order the killcoil in the US because I can't find it anywhere around here. So far I managed to find an equivalent for everything except THAT.
Well then you go to the jeweler and show him a pic of a kill coils and say, 'make me one from .999 silver or some close approximation. Or you buy a small ingot of silver and have fun with a hammer.
(and the vid card backplates which are back order but they can be added later)
