I'm not familiar with GB boards, but I'd try playing around with these options:
Realtime CPU ratio control in OS - ON/OFF (Think setting this to off might help)
Turbo Boost - ON/OFF (Should be ON to allow multiplier modification I think)
Turbo Power Limit - Max it out
Core current limit - Max it out
C1E - Personally I would disable it
EIST - Try ON or OFF
You are ****ting me?!!! Do you have ET6 installed? That is what the option is for, but something else must be changing it. That is weird!!! Sorry fever for doubting you... my several experiences with giga boards and that option however never showed that response.
