Gigabyte GA-Z87X-OC Questions
Hello
I'm looking at the Gigabyte GA-Z87X-OC Force motherboard and have a few questions if the CPU, CPU cooler and memory will work together.
The CPU is: Intel CPU Core i7 4770K Haswell 8MB Cache 3.5Ghz
The CPU cooler is: Intel BXTS13X Liquid Cooled Thermal Solution
I assume these will be ok, the sockets are, or support, LGA 1150. It's the memory I'm the more unsure of.
The CPU says it supports memory up to 1600MHz, I was thinking 2x8GB DDR3 1600MHz modules. Can I just grab any, or do they need to support the motherboard/chipset?
Thanks for taking the time to answer my noob questions.
Hello
