Hey all,
I have a client who I'm migrating over from a work group to a domain. I have the domain setup and everything. I can verify that the workstations are in fact connecting to the domain no problem.
However, I'm trying to map network drives using GPOs. I've done this MANY times. I have all of the users and I'm assigning them to their respective groups. I've created the shares and assigned permissions to them. I've created the GPO to make the drives using the "Create" function (within drive mappings). I've made sure the share locations are correct and the item-level targeting I've assigned is accurate. I've then linked the GPO to the OU which houses all of the users and groups, and also applied the GPO to specific groups (I even assigned it to the group "Domain Users" and "Authenticated Users" for testing). Then I've updated the GPOs. I log in to the user and no drives are mapped. I created a test server and client to test GPOs before applying them, and it's set up the exact same way and it works just fine. The problem persists also with a power scheme I created. It wont apply. The only GPOs that apply are things like the screen saver policies I created.
HOWEVER, I logged into the clients domain using a personal laptop, and the network drives mapped just fine and the power scheme applied. I'm not sure what's going on.
Server is Windows Server 2008 R2 and all clients are Windows XP Pro SP3. The personal laptop I signed onto their domain with (and when everything worked perfectly) is also XP Pro SP3.
I am absolutely stumped. Any help??
