- Jun 9, 2010
If you're after absolute ball to wall performance grab 2 6990s. Nobody will be able to touch you for a long while. Sure, it'll set you back about 1000 pound sterling. Maybe 1200... But it's worth it for 200fps in everything, I think.
Otherwise get a 570 or 580. 480 gets too hot.
The 570 will overclock well but the 580 overclocks great. You can each 1000Mhz from about 770Mhz stock. That's significant. Mine is at 940 only because I wussed out on voltage. Had it at 975 stable.
well not to rain on that 6990 comment, but i am pretty sure that the 590 will be better. just sayin, since 2 6970's out perform the 6990, and the 580 out performs the 6970. as for the 580 OC i haven't been able to get mine past 960 core(linked shader). but ya the 480 is way too hot and getting aged.
