Ran into some problems today so I've decided to make a guide on how to kick-start the backup BIOS.
Method #1:
1. Shut your PC down (if you're reading this guide, than your PC isn't working anyways)
2. Hold the power button until the PC starts and shuts down again
3. Press the power button again, your backup BIOS should kick in now and should re-flash the main BIOS if there's anything wrong with it.
Method #2:
2. Hold the power AND the reset button for about 10 sec, than release.
3. Backup BIOS should kick in anytime soon now.
Method #3:
Had to use this one in order to get my 990FXA-D3 working again. Backup BIOS kicked in using method #2, but I was back to the good ol' no signal state once the procedure finished..
1. Short out pins 1 and 6 on the main BIOS chip (pin #1 should be marked with a red dot or whatever)
2. Tell a friend (or a relative) of yours to press the power on button
3. Remove the ghetto-like jumper you're holding between pins 1 and 6 as soon as you hear a beep.
4. Backup BIOS should kick in again and everything will (hopefully) be fine.
Uhm yeah, that's about it, I guess.
P.S Please bare in mind that the 3rd method should only be used if you have the following options:
Option #1 Follow my dumb advices.
Option #2 RMA the board.
So far so good here!
i7 left in stock settings, turbo enabled, auto multiplayer, voltages etc. Ram left on 1600mhz with really tight timings: 7-8-8-24, everything else stock. This is like 5ft Gigabyte MB I had, no problems whatsoever with any. This one corrupted BIOS after my CPU Voltage setup mistake frankly on chipset that is not made for fiddling with it on ITX H series chipset. Any way, will keep you posted if somethings change, GPU is in configuration, everything is set and working for now.
Regards!
*SNIP*
EDIT: To answer my own question - https://www.amazon.co.uk/gp/product/B07SNTL5V6/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1 is a kit that is connected to the BIOS chip and then to another working PC which via software then flashes the chip with a hopefully working BIOS.
Of course this is all totally theoretical ATM as I've just ordered one and have no idea of the success rate or, possibly whether the hardware is defective. Since this isn't the first and won't be the last motherboard that's become unresponive it struck me as being well worth £14.00 to have the means of reflashing. I'll post back if all goes well, but it won't be here for a few days.
I also have the GA-H97-D3H and shorting pins 1 and 6 of the M_BIOS chip was the only way to get it working again. Thank you very much.Hold Pins a Little Longer (Method 3)
Method 3, which explains to short/jump/bridge pins 1 and 6 on the M_BIOS chip to kick off a routine installed in firmware which reflashes a corrupt M_BIOS with the contents of B_BIOS, worked wonders for me, for which I'd like to thank the OP.
I had eliminated all possibilities other than the motherboard, and was about to RMA the board (which entails hefty shipping charges not to mention losing the board for a few weeks) when I discovered this thread and got Method 3 to work when nothing else would.
HOWEVER … at first I couldn't get it to work, despite trying a handful of times. What finally did it for me was when I stopped paying attention to the specific instruction of letting go of the pins when the power ON single beep is heard : on my board (a GA-H97-D3H) I had to KEEP HOLDING THE TWO PINS FOR 5–10 SECONDS after the initial beep before being rewarded with this pop-up message on my display :
====== DUALBIOS ======
The main BIOS is corrupted.
Press [ENTER] to recover the
main BIOS from the backup
BIOS.
It may depend on the board, or maybe if the OP sees this he might know why … but if you have a dual BIOS board and method 3 didn't work for you and you're out of options, try it again but keep holding pins 1 and 6 with a steady hand for at least ten seconds after the initial beep, see if that doesn't do it for you. Did for me.
