- Feb 22, 2007
- Norwich, NY
- Thread Starter
- #21
Go for it, the H100 will make a huge difference. If you're going push/pull, you'll need to buy 8 extra 6 x 32 threaded screws at a hardware store as the unit only comes with 8 screws for the included 25mm fans. Come to think of it, you might need to replace those too if you're going with 38mm fans. I think the screws I bought were 1 1/4" long for my 25mm fans.
So, I'm probably looking at 8 6x32 screws at 1.5" long? and do I need nuts or are they included with the h100?
