- Mar 13, 2011
- Chaparral, New Mexico
I know have 3 threads open. I hate having so many threads on the same topic open. But the new problem is sort of good. So to get the proper input I thought it would be better to start a new thread with none of the bs from the last.
Long story short, I have my 965be at 3.8ghz at 1.38v. Temps were at 38 on idle, and just past 55 during prime. After trying to figure out what was wrong...Iv decided to get 2 new matched fans for the rad. And some new paste and to re seat the block. As suggested I may have overtightened to the point that the sides were so tight the center of the block lifted just so lightly.
Last night, pulled the door off the case. Rad and hoses were both very cool to the touch. May have tapped the block with my fingers. The pump is pumping though. I then loosened the block a tad on both edges. The retightened them down, not sure why if I thought they were too loose. I guess I figured that the paste would have gotten bubbles or something.
Well just checked my temps this morning. Idle is now 30c, max temp under prime was 47c.
This has me mind boggled. I dobnt believe that the loosening and re tigthening would have changed the temps that much much. The only thing I can think is maybe when I tapped the block, I let an air bubble loose or soemthing. Is this possible? To have bubbles even though its a fully closed loop?
Now I do have to say the temps in my room are about 5 lower than usual. I honestly dont believe this to be the culprit. Or could it? I just dont see that big of a chnge from just a slight change in the outside air. Then again, if the 4x120mm side fans are bringing in air 5c cooler, the fans from the h60 would be pulling relitively cooler air into and exhausting out. But then the rad has always been very cool to the touch, the air in my case is very cool.
Any thoughts? Im lost now. Still going to experiment with fans, going to turn the ones I have now around so they are intake.
