__________________
I bought a new P8Z77-V PRO motherboard. Put in my old Corsair Vengeance RAM (4x4 = 16 Gig). After attempting to boot, a motherboard light came on indicating that the board did not recognize the RAM. I tried the button on the board that attempts auto-configure on the timing. No luck. So, no posting happened. I replaced the motherboard with a P8P67 rev. 3.1. Again inserted the same RAM. It also did not recognize the RAM. (The speaker gives the beep code for no RAM on both boards.)
All of this was done to replace a P8P67 Rev 3.0 motherboard with damaged CPU pins. The Corsair ran like a champ on this board.
I've now tried two different processors (I5 2500K and I7 2700K). Changed out the power supply. Tried just two RAM sticks. Tried different slots. I cannot get the P8P67 3.1 or the P8Z77-V Pro to recfognize any of the RAM. So I never get to the point where I can get into the "BIOS". And yes. I cut the power, removed the battery and replaced three minutes later. Nada.
Since this time, I bought G. Skill F3-17000CL11D-8GBXL and tried it in both motherboards. Same results.
I've now ordered new G. Skills RAM listed in the manual as approved by Asus for the P8Z77-V PRO. I hope I can get this to work on the Z77 board.
But I'm really now focused on the old RAM to use for the P8P67 R3.1.
Could the higher voltage of the Z77 board have burned up the other RAM? The Corsair is 1.5 volt RAM. The older G. Skills is listed for 1.5-1.6 volts. The G.Skills RAM had a sticker on the package that said it was rated for Z77 motherboards.
I absolutely hate thinking that I may have hosed 32 Gigabytes of RAM. Any ideas?
Bach On
