- Feb 4, 2012
So my heatsink is this one:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835207009
My mobo is a MSI p35 platinum, lga 775, with a Q6600
I think the backplate is shorting something. I checked clearances and nothing seems to be touching though. After I put on the heatsink, I'll test if it boots past the CPU stage, and it will. Then after I wait a little bit it won't boot. But if I take the heatsink off, it boots.
It could be the weight of the heatsink is bowing the mobo and causing it to short on the case, but that has even more clearance than the backplate.
I really do not want to use the Intel heatsink, especially because the push pins are getting old and not working properly.
I'm considering plastidipping the entire back of the motherboard and/or the heatsink backplate. I know the company that makes plastidip has a stronger insulator coating, but computer voltages are relatively low...
Anybody else have experience with a heatsink that creates booting problems?
