boastdetail
- May 29, 2014
I've been searching for two days, so I upgraded my heatsink and my dad pulled it out of the AM3 slot prior. Out comes the cpu and heatsink, bent and all. I fix all the pins, readjust the grip three times. The computer turns on and stays on. But there is no display or post. Could I have short circuited the cpu? It definitely works since its connected to the socket since I just ran it without the heatsink, overheating 3 seconds later. I have a new ssd and old hdd connected. The top fan conne cted to the rear fan only cycles when shutting down. It usually just cycledz after bios before this issue if I recall correctly. No, we weren't grounded. We both touched the cpu. Damaged pins don't seem to be an issue here. Please, help . I'll be buying an 8350 soon.
The 8320 works but doesnt post.
Also the front of my case doesn't blink the tiny blue dot like it did.
I went over the manual 5 times I'm sure the wiring is right. I can't find the speaker cable for beeps. Ssd shines green light.
Can cpu be faulty while still heating up?
Also since the mobo shut down the comp to prevent burning, does that eliminate the mobo from faulty?
Possibly crushed cpu installing hyper 212 evo. Only three standoff were supplied too so that can be an additional factor.
