AG boki v1
- Jun 17, 2012
i just bought an amd phenom II x4 960 and 8gb of ram ddr3 1600mhz
my question is.
does my cpu support 1600mhz ???
my question is.
The CPU does.. What motherboard are you putting it in?
Technically speaking, none of the current AMD CPUs support 1600 ram speed. They are all rated for 1333. In the real world, however, the Thuban core Phenom IIs and the FX bulldozers will run with 1600 ram speed without a problem and the FX bulldozer will do 1866 ram speed without a problem. Those two have a more rugged ICM (Integrated Memory Controller) even though they are still rated at 1333 mhz. Typically, the Deneb core CPUs will not be stable with the ram at 1600 mhz. What's more, there is almost no performance gain when going to 1600 from 1333 mhz. http://www.anandtech.com/show/4503/sandy-bridge-memory-scaling-choosing-the-best-ddr3/6
