Hi guys,
I recently installed an i7 7700k on a new Asus Prime Z270M-Plus. I have a hyper 212 evo that I have used for the past few years on my old Fx 6300.
I also have 16gigs DDR4 Ram and an R9 280x.
I was recently playing heroes of the storm, on 1440p, max settings etc, which should be easy to do, and it was running very smooth the first day I used this comp.
The game started getting really choppy, and my Core Temp program was showing heat spikes of 90-100C on some of the cores. They would then flash back down to like 60 then jump to 90 all within a second or two. It seemed strange.
Anyway, my question is two fold: Would a cpu getting really hot like that cause a game to start slowing down and getting choppy. And also, is a Hyper 212 evo a good enough cooling device for this cpu? If not, what would be better? I'm not sure I want anything crazy intense, I don't know much about water cooling, but I guess I am open to it?
Here is a picture of my case: https://www.newegg.com/Product/Product.aspx?Item=N82E16883258078 This was a comp I bought years ago, have since replaced literally everything but the case.
Any help would be appreciated.
Thanks!
Thanks!
