- Jan 25, 2014
Hey guys this is my first water cooling build. The motherboard and CPU are a little older but they work for me right now. The specs are
Corsair 900d
CPU-I7 2600k
Asus Maximus v formula
EVGA g2 750 watt PSU
16gb ddr3 2133 MHz ram
EVGA gtx 970
The water cooling parts are all EK and nickel plated. The rads in the top and base of the case are EK PE 480mm with only one set of fans. Setup in push for the bottom rad and pull for the top rad. My goal was to keep it quiet. But I'm kind of stuck now. I don't know if I should go hard tubing(PETG) or soft because I'm sure I'll be upgrading components sometime later this year. So I'm just looking for some help on deciding on the tubing and the fitting to go with it. And also some help to get the best routing.
Corsair 900d
CPU-I7 2600k
EVGA gtx 970
